https://forum.mxlinux.org/viewtopic.php ... 66#p664466
Last entry on the linked thread is from a user that says he had issues using the method shown. FYI.
System: Kernel: 4.19.118 i686 bits: 32 compiler: gcc v: 8.3.0
parameters: BOOT_IMAGE=/boot/vmlinuz-4.19.118
root=UUID=<filter> ro reboot=pci quiet splash
Desktop: Xfce 4.14.2 tk: Gtk 3.24.5 info: xfce4-panel wm: xfwm 4.14.0 vt: 7
dm: LightDM 1.26.0 Distro: MX-19.4_386 patito feo October 15 2019
base: Debian GNU/Linux 10 (buster)
Machine: Type: Laptop System: Matsushita product: CF-29LTQGZBM v: 004 serial: <filter>
Mobo: Matsushita model: CF29-4 v: 001 serial: <filter> BIOS: Phoenix K.K. v: 4.00L11
date: 07/19/2005
CPU: Info: Single Core model: Intel Pentium M bits: 32 type: MCP arch: M Dothan family: 6
model-id: D (13) stepping: 8 microcode: 20 cache: L2: 2 MiB
flags: nx pae sse sse2 bogomips: 3191
Speed: 1600 MHz min/max: 600/1600 MHz Core speed (MHz): 1: 1600
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Type: l1tf status: Vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: meltdown status: Vulnerable
Type: spec_store_bypass status: Vulnerable
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics: Device-1: Intel Mobile 915GM/GMS/910GML Express Graphics vendor: Matsushita
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:2592 class-ID: 0300
Display: x11 server: X.Org 1.20.4 compositor: xfwm4 v: 4.14.0 driver: loaded: intel
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 270x203mm (10.6x8.0")
s-diag: 338mm (13.3")
Monitor-1: LVDS1 res: 1024x768 hz: 60
OpenGL: renderer: llvmpipe (LLVM 7.0 128 bits) v: 3.3 Mesa 18.3.6 compat-v: 3.1
direct render: Yes
Audio: Device-1: Intel 82801FB/FBM/FR/FW/FRW AC97 Audio vendor: Matsushita
driver: snd_intel8x0 v: kernel bus-ID: 00:1e.2 chip-ID: 8086:266e class-ID: 0401
Sound Server-1: ALSA v: k4.19.118 running: yes
Sound Server-2: PulseAudio v: 12.2 running: yes
Network: Device-1: Marvell 88E8053 PCI-E Gigabit Ethernet vendor: Matsushita driver: sky2
v: 1.30 port: 3000 bus-ID: 02:00.0 chip-ID: 11ab:4362 class-ID: 0200
IF: eth0 state: down mac: <filter>
Device-2: Intel PRO/Wireless 2915ABG [Calexico2] Network driver: ipw2200
v: 1.2.2kmprq port: 3000 bus-ID: 06:02.0 chip-ID: 8086:4223 class-ID: 0280
IF: eth1 state: up mac: <filter>
Drives: Local Storage: total: 119.24 GiB used: 52.48 GiB (44.0%)
SMART Message: Unable to run smartctl. Root privileges required.
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD SM841N mSATA 128GB
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: <unknown>
type: SSD serial: <filter> rev: 5D0Q scheme: MBR
Partition: ID-1: / raw-size: 117.21 GiB size: 114.87 GiB (98.00%) used: 52.47 GiB (45.7%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
Swap: Kernel: swappiness: 15 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 2 GiB used: 11 MiB (0.5%) priority: -2
dev: /dev/sda2 maj-min: 8:2
Sensors: System Temperatures: cpu: 63.8 C mobo: N/A
Fan Speeds (RPM): N/A
Repos: Packages: note: see --pkg apt: 2008 lib: 1006 flatpak: 0
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/debian-stable-updates.list
1: deb http://deb.debian.org/debian buster-updates main contrib non-free
Active apt repos in: /etc/apt/sources.list.d/debian.list
1: deb http://deb.debian.org/debian buster main contrib non-free
2: deb http://deb.debian.org/debian-security buster/updates main contrib non-free
Active apt repos in: /etc/apt/sources.list.d/mx.list
1: deb http://mirror.it.ubc.ca/mxlinux/mx/repo/ buster main non-free
Active apt repos in: /etc/apt/sources.list.d/softmaker.list
1: deb http://shop.softmaker.com/repo/apt wheezy non-free
No active apt repos in: /etc/apt/sources.list.d/various.list
Info: Processes: 183 Uptime: 44m wakeups: 2 Memory: 1.46 GiB used: 1.22 GiB (83.5%)
Init: SysVinit v: 2.93 runlevel: 5 default: 5 tool: systemctl Compilers: gcc: 8.3.0
alt: 8 Shell: quick-system-in default: Bash v: 5.0.3 running-in: quick-system-in
inxi: 3.3.06
