CF-18 backlight
Barney
CF-18 backlight
#1 Post by Barney »
I have 2 CF-18, the backlight failed on one.
Did some research and most links that I found point to the backlight inverter.
So I did a one for one swap, still no backlight, the original (suspect) inverter works perfectly in my other CF-18.
So it wasn't / isn't the inverter.
Any ideas?
2 x CF-18, 1 x CF-19
Re: CF-18 backlight
#2 Post by ADOR »
It's the bulb at the bottom of the screen. You would have to either find a busted screen and I think you can rob the bulb from the bottom of the screen and replace it. (It has been a long time since I messed with any bulbs, I can't remember how easy the bulb it's self pulls out.)
Option two find a 18 to 19(Mk1,2 only) screen and swap it.
Barney
Re: CF-18 backlight
#3 Post by Barney »
Thanks for the reply.
So much for fixing my beater, it's getting stripped now.
