Just an FYI.... I recently replaced the protective overlay (plastic film) on my CF-29. I purchased the replacement from http://www.photodon.com. There is a specific section he has for Panasonic Toughbook, actually CF-30. My thought was that the screen size from the 30 is 13.3 and my 29 is 13.3. I ordered 2, one is the new "crystal clear" type and the other is the "matte" finish... Easy to install, and looks and fits like OEM. They are $13 to $16 per film. A lot cheaper than OEM and in my opinion just as good if not better..
Just my 2 cents...
GREAT SCREEN PROTECTORS!!
- copracer1990
If it isn't broken, take it apart to see why it is working!!
(1) CF30CCS80BM~TOUCHSCREEN~1.6GhzCORE 2~80g HD~4G RAM~EMISSIVE BACKLIT~INTEL 4965ABGN~GOBI~WINDOWS 7 ENTERPRISE~
(1) CF29LWQGCBM~TOUCHSCREEN~1.6Ghz~1.5G RAM~RUBBER BACKLIT~INTEL2915ABG~80g HD~WINDOWS 7 ENTERPRISE~
(1) CF27LBAGHEM~TOUCHSCREEN~500Mhz~512MB RAM~DUAL BOOT XP & WIN98SE~60g HD~ EMISSIVE BACKLIT~GREAT FOR PROGRAMMING MY 2 WAY RADIOS~
(1) CF-M34~TOUCHSCREEN~unknown specs for running OBDII scanner~
Re: GREAT SCREEN PROTECTORS!!
Yes, I have used them on my cf-29's
Have a nice screen cleaning cloth from them that they sent as a frebee a few years ago
I just hate changing the scratchsheets, as I always get a bubble or two
Alex
Alex
