CF-19 LCD and touchscreen
Hi, I have a CF-19 model number CF-195HAC8MN. After what I managed to read, it is supposed to be a MK7 (with a i5).
Unfortunately, the LCD and the touch screen are broken.
Now to the question, from what I see when I read the specs, this seems to be a 10.1" screen. The replacement screens and touchscreens that I can find om Ebay however seems to be 10.4"
Are the different variants of the CF-19 screens and are the 10.4” compatible or if not, where can one you buy replacement LCD and touchscreens?
Best Regards
Lars
Best Regards
Lars
Re: CF-19 LCD and touchscreen
They're all the same AFAIK, only the screen itself is slightly smaller. (not mechanically but the LCD itself has those .3 inch bars)LarsL wrote:Hi, I have a CF-19 model number CF-195HAC8MN. After what I managed to read, it is supposed to be a MK7 (with a i5).
Best Regards
Lars
I am pretty sure you will need a panel from a mk6 or mk7.
They are all the same size, but there is a significant difference in brightness.
mk6 and mk7 also have the sensor in the lid to adjust screen brightness automatically.
mk1 and mk2 have a ccfl backlight while mk3 and later use a led backlight.
The touchscreen panels are all the same as far as I know.
CF-195HAC8MN
Core i5 3340M / 2.7 GHz,
Windows 8 Pro,
4 GB RAM, 500 GB HDD,
10.1" Touch 1024 x 768,
Intel HD Graphics 4000,
Bluetooth, 3G, tastatur: Nordisk
CF-195HAC8MN
Windows 8 Pro,
Hi and thanks for your answers.
So my question, where can I order a touchscreen and a LCD that is 10.1 "which fits in my 10.1" bezel. I do not desire to order, pay and buy something which I then cannot use.
Lars
Lars
Locate a dealer in your country.
http://www.panasonic.com/global/corpora ... y.html#euc
http://toughbookparts.nl/
Official service center is located in the UK.
http://business.panasonic.se/datorprodu ... vicecenter
Hope you got deep pockets because TB parts don't come cheap in Yurop.Shawn wrote:Locate a dealer in your country.
I would also say that it is the problem. Even if you get to buy a new touchscreen and LCD element from Panasonic, the cost as spares wouldt probably be more than your computer is worth.
I've thought about trying to find a third-party parts on Ebay or similar. Have many times managed to find impossible spareparts for other computers there. Sadly I can only find 10.4" elements right now.
Thanks for the table. It seems as if it were from the MK7 6500 in brightness.
If you want to sell that mk7 as-is, let me know. I may be interested.
