Can any come up with the proper WWAN IDs for the "Optional Kit" screen in BIOS?? I was curious if anyone has or can get their hands on this info??? This is what I have so far from my CF31-MK3
AT&T MC7700 is "8"
VZW MC7355 is "f"
Thanks in advance.....
WAN "ID's" for various WWAN CARDS
- copracer1990
If it isn't broken, take it apart to see why it is working!!
(1) CF30CCS80BM~TOUCHSCREEN~1.6GhzCORE 2~80g HD~4G RAM~EMISSIVE BACKLIT~INTEL 4965ABGN~GOBI~WINDOWS 7 ENTERPRISE~
(1) CF29LWQGCBM~TOUCHSCREEN~1.6Ghz~1.5G RAM~RUBBER BACKLIT~INTEL2915ABG~80g HD~WINDOWS 7 ENTERPRISE~
(1) CF27LBAGHEM~TOUCHSCREEN~500Mhz~512MB RAM~DUAL BOOT XP & WIN98SE~60g HD~ EMISSIVE BACKLIT~GREAT FOR PROGRAMMING MY 2 WAY RADIOS~
(1) CF-M34~TOUCHSCREEN~unknown specs for running OBDII scanner~
Re: WAN "ID's" for various WWAN CARDS
FYI: Optional Kit Configuration password is "toughkit", as mentioned on NBR.
- Karl Klammer
cf19mk6 with F5521GW UMTS/3G module has WWAN ID "7"
Thanks for relaying that info User32, always wondered what that menu item would hide ...
just 1 primitive settings ... it's a bit disappointing ...
do other cheatcodes with more exciting settings exist?
EDIT:
NBR member springfield has "CF-53 with Gobi 2000, the WWAN code is 04"
EDIT:
BOOM:
List of WWAN card models for Toughbooks:
DISCONTINUED:
SB555 – 1xRTT (2G) carrier specific modem – Sprint, Verizon, & Alltel.
EM5625 – Sierra Wireless branded - Sprint, Verizon and Alltel specific EVDO rev0 CDMA cards.
MC5725 – Sierra Wireless branded - Sprint, Verizon and Alltel specific EVDO revA CDMA cards.
EU860D – Novatel Expedite branded 3.6M HSPA GSM modem (Upgradable to 7.2M HSPA+).
EU870D – Novatel Expedite branded Traditional 7.2M HSPA+ GSM card.
GOBI 1000 (xxGOBI1000FU) – Qualcomm branded “Multi-carrier” 3G card – Sprint EVDO revA CDMA, Verizon EVDO revA CMDA and AT&T 7.2M HSPA+ GSM.
CURRENT:
GOBI 2000 (xxGOBI2000FU) – Qualcomm branded “Multi-carrier” 3G card – Sprint EVDO revA CDMA, Verizon EVDO revA CMDA and AT&T 7.2M HSPA+ GSM. Also has independent GPS cabilities. Option Kit config code: 04
MC7750 (xxV4GLTEFU)– Sierra Wireless branded Airprime - 4G LTE Verizon Specific card (Win 7 Only) – Not licensed for Win8. Option Kit config code: 01
MC7700 (xxA4GLTEFU) – Sierra Wireless branded Airprime - 4G LTE AT&T specific card (Win 7 Only) – Not licensed for Win8. Option Kit config code: 08
MC8355 GOBI 3000 (xxGOBI3FU) – Sierra Wireless/Qualcomm dual branded – “Multi-carrier” 3G card – Sprint EVDO revA CDMA, Verizon EVDO revA CMDA and AT&T 7.2M HSPA+ GSM. Option Kit config code: C
MC7355 GOBI 5000 (xxGOBI5000FU) – Sierra Wireless/Qualcomm dual branded - 4G LTE multi-carrier card – Licensed to work with Windows 8/8.1. Option Kit config code: 0F
MC7710 Euro Card – Option Kit config code: 15 or 16
EM7355 GOBI 5000 – Option Kit config Code: 13
KEY: xx = 19,31,52, 53, C1, C2 or whatever Toughbook model you’re putting it into.
DISCONTINUED:
CURRENT:
- copracer1990
Great info ROB!!! Thanks for keeping this going!!
