CF19 MK2 Camera Memory upgrade
Mono
#1 Post by Mono »
Hello
I have a cf19 mk 2 with the built in camera.
It currently has 2 GB ram.
32 bit win 7
There is only one ram slot, is it possible to upgrade the memory?
User32
Re: CF19 MK2 Camera Memory upgrade
#2 Post by User32 »
There's no real value-for-money upgrade for a camera equipped model, you could put in a 4GB DDR2 module but IMO it's better just to upgrade to a 19 Mk4 or up.
#3 Post by Shawn »
I would bump it up to 4gb and keep Win7 32bit on it.
#4 Post by toughasnails »
Shawn wrote:I would bump it up to 4gb and keep Win7 32bit on it.
Just like Shawn said but I would also upgrade the harddrive to a SSD. You will really see the difference then .
Rich
#5 Post by Rich »
I agree, max ram and a ssd sure made a difference in my 29s and my 19. I get my ram from Crucial, the prices are good and it's not some weird off brand for a few bucks less.
We get some rules to follow.
CF-20 Mk1, CF-31 Mk5 i7, CF-31 Mk6 i7, FZ-G1 Mk2, CF-54 Mk2, CF-33, FZ-Q2, CF-74J,
#6 Post by toughasnails »
Smart move. Crucial is the best to get and only a few bucks more.
Mono
#7 Post by Mono »
So there is only one memory slot on the motherboard, can I put 4Gb in that?
Rich
#8 Post by Rich »
4gb is the max for your unit. Are you sure there is only one slot? Crucial says 4gb max 2 slots. If thats the case, you could just buy another 2gb for $26.99. Anybody else know for sure?
#9 Post by Shawn »
Camera models have only one slot.
The CF 19 mk2 U7500 cpu with a GM965 chipset.
As per the Intel page, the GM965 only supports 4gb. http://ark.intel.com/products/29821/Int ... Controller
So Like I said before bump it to 4gb and keep Win7 32bit.
32bit can only use 3.3gb of memory anyway.
Unless you are doing HUGE projects, you don't need 64bit Windows. And without a 64bit OS more than 4gb of memory will be unusable and a waste of money.
You should be able to put a 4gb stick in the one slot. I will do a search.
Mono
#10 Post by Mono »
Thank you I appreciate your input very much.
