My CF-30 Mk2 has a Vista COA, but the spec sheet says XP Downgrade. I need the XP restore disc so it will install and activate properly.
I also need the corner bumper for the lid + screws. Right side if you have a CF-30 open and looking at the screen - same side where the GPS antenna goes. I'm sick of the GPS sticking out and I never use it, so I just want the plain cover. I'll take a used one that's in good shape and clean.
Would like to spend $20 - let me know if you have what I'm looking for and that sounds ok to you. Thanks!
WTB: CF-30 Mk2 XP Recovery & Right Corner Lid Bumper
Re: WTB: CF-30 Mk2 XP Recovery & Right Corner Lid Bumper
I took one off today. Now where did I throw it? Are you pulling the GPS too? Worth a little....I DON'T NEED IT.
PM your address and I will reply with my paypal.
