Wanted-CF-30/31 genuine toughbook fieldmate info case
Looking for a new or used genuine CF-30 or CF-31 toughbook case or fieldmate info case.
						Re: Wanted-CF-30/31 genuine toughbook fieldmate info case
Do you mean the nylon version?
what types do you get? think it is nylon.
The Fieldmate is nylon.
That will do have you got one?
No I do not.
Just the links on ebay.
have tried uk nothing have you any links USA?
Hi sorry this is what i intended to list-
(TBC31CASE-P) Toughmate 31 Sling Case or the CF-30 equivalent, I think there is also a fieldmate infocase or anything that will cover the CF-30 and has space for some cables.
Retail dealers and ebay
http://www.ebay.com/itm/Panasonic-Infoc ... SwGotWqo~-
here from newegg
http://www.newegg.com/Product/Product.a ... 8H53970418
here from provantage
http://www.provantage.com/panasonic-cf- ... SOT09A.htm
here
http://www.plccenter.com/en-US/Buy/PANA ... irect=true
here from newegg
here
Thanks Shawn much appreciated for taking the time to find the links, will have a look through them.
Cheers
						Cheers
