Emessive Keyboard Failure?
Azrial
#1 Post by Azrial »
On my new CF-31J the keyboard is not nearly as bright as my old CF-31A. I have not had one long enough to know, is this a sign of impending failure, or is it correctable?
Azrial
Re: Emessive Keyboard Failure?
#2 Post by Azrial »
As no one has reported that their keyboard has failed, or become dimmer, I guess that I will have to assume that my problem is electrical. I have a very bright keyboard in my old CF31, but did my want to do the swap if it pointless.
#3 Post by Shawn »
Did you try the hotkey setting for the 3 or 4 brightness levels?
Azrial
#4 Post by Azrial »
Yep, max brightness is less then half of my old one. If the keyboards do not lose brightness over time, I may be looking at an electrical issue. I would not think that it is a big deal, just trying to figure it out.
#5 Post by Shawn »
They just have 4 or 6 leds in them. Not much to really go "dim" I would try reconnecting it into the motherboard. Maybe a dirty connection.
Check in the BIOS for conceal mode settings.
Azrial
#6 Post by Azrial »
Thanks, this sounds like good advice!
Azrial
#7 Post by Azrial »
Well, I pulled out the keyboard of my new CF-31J and cleaned the edge connector with a pencil eraser, GENTLY, and that seemed to do it. It is as bright as the old CF-31A now, which is still for sale... : )
#8 Post by SHEEPMAN! »
1. I never got an answer from the door guy.
2. I have no idea how old the keyboard was. I'm so happy that you got it sorted out.
XXXX :)
Azrial
#9 Post by Azrial »
Thanks, the keyboard is running great! The whole machine is. I am super happy with it!
