CF-M34 Wifi
- Silver Trooper
CF-M34 Wifi
For any of you out there that have worked with the M34's, how was wifi incorporated in the 1.0Ghz model? Did they use an additional board and if so how was it interfaced with the mobo? I am still trying to obtain a 1.0Ghz but haven't yet. By any chance has anyone incorporated wifi into an M34 without using a PCMCIA or USB device?
Re: CF-M34 Wifi
I think they were Mini PCI cards with the mini coax antennas that go into the screen for the signal...
Re: CF-M34 Wifi
Hi, i have a 933 Mhz and i mounted a Engenius card inside with an external sma antenna.
There is a mini pci slot inside, only minus, after that you don't have a wired lan anymore.
You can always put a pcmcia lan card in it.
Btw, he is for sale on Ebay now
http://cgi.benl.ebay.be/ws/eBayISAPI.dl ... :MESELX:IT
Re: CF-M34 Wifi
You may use this board in order for you to have dual mini pci slot and this board is rare. I have seen it only on ebay for twice in two years. Here is the item no.120509816887
Re: CF-M34 Wifi
Teo, if my co-worker gets this mini board for the M34 then can he now have the hibernate option in XP?!?!? He can't hybernate his macine which sucks... (IE: different BIOS??)
- Silver Trooper
Re: CF-M34 Wifi
TEO! Thank you...thank you...thank you! I plugged in that part number in Google just to see if anything would pop up. Lo and behold, the ONLY reply was a listing for an item on Ebay. Come to find out it was posted on 29 Dec and it was $48 BIN and only $3 shipping. I have been trying to find one of those for months since I did want to pay $200-300 for a 1.0Ghz CF-M34 as it was the only one with this card. What a deal!teo wrote:You may use this board in order for you to have dual mini pci slot and this board is rare. I have seen it only on ebay for twice in two years. Here is the item no.120509816887
Thanks again!
Robert
Re: CF-M34 Wifi
ST....I was hunting that two years ago but no luck coz I wanna make my unit to be wireless without loosing the NIC and modem but no luck. Instead I sold my cf-m34 933mhz. That board can be install to 300mhz, 400mhz, 700mhz, 866mhz and 933mhz.
Remember that the second mini pci accept only orinco, siemnens, cisco and intel If i am not mistaken. Good Luck.
- Silver Trooper
Re: CF-M34 Wifi
Now may be a good time to pull the Intel card from one of my other Toughbooks and replace with the 600mw card so I can use the Intel in the CF-M34.
