If I'm understanding your description, could have been headset or microphone jack, wireless switch, screen area under latch, or around indicator lights.
Somebody put a couple drops of liquid in the headset jack of a running CF-52 and see what happens.
I pulled the 7 shaped door for the bios chip and wireless card. A bright light shining from the handle side through the black screen is clearly visible near plenty of fuses.
Sorry for your trouble.
CF-52 MK II no power
Re: CF-52 MK II no power
Hey hey hey. Don't go putting 52's down. The one that I have is actually near and dear to me. She's become my keep at the shop machine. Replaced my 74's in that aspect.safn1949 wrote:I just bought a 52mk2 for $50 shipped today,not even worth fixing when they can be had for that price.
Should be here on or about Sept 8th.Twocents wrote:I'm not in a hurry. I'll try and check for messages here daily until I hear from you.
Sounds good.safn1949 wrote:Should be here on or about Sept 8th.Twocents wrote:I'm not in a hurry. I'll try and check for messages here daily until I hear from you.
Sadlmkr -
I hadn't thought of the jacks, I'll have to check that out. As far as I can tell the area around the bios/wireless is dry and shows no sign of being wet. Thanks for the well wishes, these things happen. I'm really attached to the form of the CF-52, it works better than any other laptop I've owned. I need to save my pennies for a CF-54! I'm sure I'll be able to afford one in a few years once there are enough of them on the used market.
Bill_TN -
I agree with you about knocking the CF-52. The whole reason I got my first one was because they are so reliable, minus user error... I'm sure that it's not any kind of a record, but I think the last time I looked at the time in bios it was 26K hours or so and I suspect that's better than most other brands. On the other hand my wife has gone through two other laptops and wants another one. I'm planning on dropping a SSD into the CF-52 and keep on going with one. New and shiny are all well and fine, but most people, myself included, don't need the latest and greatest.
Bill_TN -
