CF-31P and touchpad (Interlink Versapad)SAGA CONTINUES WORKS
Re: CF-31P and touchpad
Jeff,
I contacted some locals that are familiar with The Alps. I think that you and them speak the same language. I bet they can moove you to a solution.
That's exactly what he needs. MORE LIVESTOCK!!Shawn wrote:Jeff,
Jeff, you missed a slash:
ls -l /dev/input by-path
ls -l /dev/input/by-path
http://askubuntu.com/questions/398568/p ... 518#417518
https://bbs.archlinux.org/viewtopic.php?pid=1189603
I'd be tempted to try the last one first since it seems to be the easiest. Do these as root of course:
edit /etc/default/grub then add "i8042.notimeout i8042.nomux" to GRUB_CMDLINE_LINUX_DEFAULT
update-grub
reboot
I presume you've already added kernel parameters in /etc./default/grub before.
It should look like this:
GRUB_CMDLINE_LINUX_DEFAULT="i8042.notimeout i8042.nomux"
Thanks Shawn for the Alps experts but mooving right along....
Cleve I read your stuff.
"Upgraded CF-31 and at least one CF-19 are using Interlink Versapad" my quote from this: http://www.printedelectronicsworld.com/ ... ughbook-19
This gave me a couple more keywords to search for. Which is where I am now.......(Interlink,versapad,Linux,Debian,touchpad)
I'll swap drives in a bit. Prefer to work on this type of problem from the machine that is ill.
When I loaded the driver bundle the installer threw a 1633? code......"Thu 08/13/2015 ERRORLEVEL:1633" One time only. Need to check this for clues.
I'll run this anyway for general information....I knew that a slash should be there but thought it was special or something.
So mooving on.
So mooving on.
kodeniner: There is a typo after etc (a period)(full stop)(dot) In your post. Readers this means it should read /etc/default/grub # Not complaining, thanks for the help.
Back in a second on Linux.
li@cf30kforc:~$ ls -l /dev/input/by-path
total 0
lrwxrwxrwx 1 root root 10 Aug 19 06:11 pci-0000:00:1d.0-usb-0:1.2:1.0-event-kbd -> ../event16
lrwxrwxrwx 1 root root 10 Aug 19 06:11 pci-0000:00:1d.0-usb-0:1.2:1.1-event-mouse -> ../event17
lrwxrwxrwx 1 root root 9 Aug 19 06:11 pci-0000:00:1d.0-usb-0:1.2:1.1-mouse -> ../mouse2
lrwxrwxrwx 1 root root 9 Aug 19 05:57 pci-0000:00:1d.0-usb-0:1.6:1.0-event-mouse -> ../event8
lrwxrwxrwx 1 root root 9 Aug 19 05:57 pci-0000:00:1d.0-usb-0:1.6:1.0-mouse -> ../mouse1
lrwxrwxrwx 1 root root 9 Aug 19 05:57 platform-i8042-serio-0-event-kbd -> ../event0
lrwxrwxrwx 1 root root 9 Aug 19 05:57 platform-i8042-serio-2-event-mouse -> ../event7
lrwxrwxrwx 1 root root 9 Aug 19 05:57 platform-i8042-serio-2-mouse -> ../mouse0
lrwxrwxrwx 1 root root 9 Aug 19 05:57 platform-pcspkr-event-spkr -> ../event6
li@cf30kforc:~$
Just to do it right.
total 0
li@cf30kforc:~$
Hehe, butterfingers.
Found this on boobtube:
http://www.youtube.com/watch?v=gzikYEX0OEQ
It's a bit annoying to watch him fumble around to get a root shell, but he eventually manages to edit the default grub file. He puts it on another line and adds a few extra i8042 parameters to get it to work, though.
I don't watch if I can help it.
The touchpad is not the same as I am used to but is working after this "fix"
This worked fine.I presume you've already added kernel parameters in /etc/default/grub before.
Code:
If you have another kernel boot parameter in there, just add the new stuff separated by a space, between the quotes.
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="i8042.notimeout i8042.nomux quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
CHANGES:
PRESS AND HOLD UPPER RIGHT SCROLLS UP "FAST" ALL THE POSTS"
PRESS AND HOLD LOWER RIGHT SCROLLS DOWN "FAST" ALL THE POSTS"
JUMPY RASCAL
ABOVE WAS LINUX MINT DEBIAN. REMEMBER TO UPDATE-GRUB.
THIS WAS WRITTEN ABOUT CF-31P....SOME CF-19 MAY ALSO USE THIS PAD. SOLVED!
JUMPY RASCAL
BTW..They are NOT livestock..They are IT.
Changes made on Makulu 9. Working dandy.
It is a bit early....you missed me with IT. Maybe LT. lactation technicians.
here's xinput now.
here's xinput now.
j@mak9:~$ xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Fujitsu Component USB Touch Panel id=9 [slave pointer (2)]
⎜ ↳ ImPS/2 Generic Wheel Mouse id=11 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=10 [slave keyboard (3)]
↳ Panasonic Laptop Support id=12 [slave keyboard (3)]
