trackpad and mouse freezing
sakkara
#1 Post by sakkara »
cf-19 mk5
whenever i try to load software both usb mouse and touch-pad freeze at the first confirmation screen
only way to continue the install is to use the stylus to click yes after that software installs and and both mouse and touch-pad work fine
have tried unplugging usb mouse and track-pad still frozen
this has a brand new copy of windows 7 64 bit from an original panasonic recovery ISO
i have an identical unit which has the exact same issue
help please :damnit:
Re: trackpad and mouse freezing
#2 Post by Springfield »
Reset all BIOS settings to default (last screen), if you have not already.
#3 Post by SHEEPMAN! »
Does this have USB 3.0? I just added USB30 driver for CF-53A to this unit. 53AAGZX1M.
Is your device manager error free?
sakkara
#4 Post by sakkara »
no usb3
no errors in device manager
tried resetting bios makes no difference
#5 Post by Shawn »
Do the complete install without the usb mouse..
When it is completely installed and ALL windows updates are done, Install the mouse driver, Then connect the usb mouse..
What software are you trying to install?? Windows?
sakkara
#6 Post by sakkara »
loaded it from original panasonic recovery dvd so cant see it be ing a driver issue ??
#7 Post by toughasnails »
sakkara wrote:loaded it from original panasonic recovery dvd so cant see it be ing a driver issue ??
Well it does happen, it's always the WiFi card with me...never the mouse
sakkara
#8 Post by sakkara »
so how do i load it from recovery without loading usb mouse drivers ?
its fully automatic
or can you bypass install somehow ?
#9 Post by Shawn »
Do not plug the usb mouse in until everything is installed and running properly.
Use the touchpad during the install process.
