Wireless drivers...which one ??
I have a CF-18BHAZXKM and I just used the recovery disk to install everthing but can not get the wireless going , installed the new intel 2100 drivers but still no luck. Before I used the recovery disks I installed XP OEM used one of these drivers and it worked great but not sure which one I used. Any idea which one to use ??
Blair
Blair
Blair
Re: Wireless drivers...which one ??
I guess the first one is for overseas. Tried the second one but still no wireless.
Blair
Blair
Blair
You have to go into the wireless properties and make sure that the wireless enable button is on
Look in all the property pages as I cannot remember where that is lol
Download the drivers from intel
I will post a link in a bit
Alex
Alex
Ok
This is the procedure to get it working
Go into wireless properties
The first tab is called general
It will list your card there, on my mk-2 is says intel 2200bg
Click configure
under the advanced tab it has a wireless on ,or off button
make sure its on
Report back your findings
Alex
Click configure
make sure its on
Alex
In device manager / Network adapters it list it as a " intel pro/wireless LAN 2100 3B Mini PCI Adapter "tomcat57 wrote:Blair
I beleve that your wi-fi card is a 2200bg
Are you positive you have an 2100b card?
Alex
Yesterday I noticed that it said " radio off " but could not turn it on. So I figured I would start over again and reinstall the drivers
Blair
Blair
Well I did notice one thing the wireless switch was not installed . I got it installed and I now have it in my task bar and its turned on. Now I will have to wait untill I get home to try it..@ work , no wifi here
I will let u know how it goes
Blair
Blair
Blair
Yes it depends on the model, some have the software switch to enable
I will post the link to the recommended drivers from Intel
Just unzip and place in a folder and in device manager update to this version, even if you have to force it
http://downloadcenter.intel.com/Detail_ ... 4&lang=eng
I do not use or like the proset software
I let windows manage the connection
The 2100b are junk
I toss them out and replace them all the time
Lack of throughput and even signal quality is the issue with these very dated cards
I would as soon as possible upgrade to at minimum to a 2200bg card
Its 10 times better and only $10 on eBay
Alex
The 2100b are junk
Alex
Thanks for the link Alex. I must of been the wireless switch that was not installed. I just came home from work and started it up......wireless found. But I will replace it . I remember you telling someone about the 2100 and how crappy it was. These wireless cards are not the same as the CF-29's are they ?
Blair
Blair
Blair
Blair
Yes I thought it would be the switch
The mk-1 is the only cf-29 that uses the 2100b card
You will loose the centrino designation in the bios when you update the card
The laptop will start up and say Pentium M as it needs to see a 2100b card
It makes no difference to the performance other that speeding up your wi-fi connection 500%
Alex
Alex
Is this the card I am looking for ? Just like the one in my 29.
Blair
Blair
Blair
