CF-19CHBAFBE Mk1 Touchscreen Not Working Win XP
Re: CF-19CHBAFBE Mk1 Touchscreen Not Working Win XP
First guess is the cable is bad...Usually they go bad around the hinge assembly.
They changed the TSPCB (yep, that's it's name) connector for some of the 19 series. Where the CF-29 had a rugged spring loaded connector the 19's (some/most/all?) have the little flimsy brown slide. That is where it should be taped down.
Pull the lid and take a look.
I had one CF-18 with a broken wire around the swivel hub....still working after my repair as far as I know. Like soldering hair. Quick check might be to swivel it around and see if you get reaction.
If not the wire and not the TSPCB then it's panel de-lamination. Common for MK1.....instant fix with a new panel.
Job done
Changed the panel and we are working![:D :D](./images/smilies/biggrin.gif)
Next question, does anyone have a Mk1 Vista Recovery Disk?
![:pbjt: :pbjt:](./images/smilies/banana.gif)
That it's dead...which it does not surprise me since it is a MK1.
![:spinny: :spinny:](./images/smilies/happy3.gif)
Good show!Banshee wrote:Job done![]()
Check with Rob when he gets back for the restore disk.
Is this what you COA sticker is "Vista" ?? I think Rob only has XP for the MK1.Banshee wrote:
COA is for XP but I have some genuine codes from my MSDN accounttoughasnails wrote:Is this what you COA sticker is "Vista" ?? I think Rob only has XP for the MK1.Banshee wrote:
![:) :)](./images/smilies/smile.gif)
That might be ok for most laptops but since your Toughbook is XP then it will only let you use the XP Restore Disk. If you try to use the Vista restore disk it will tell you that it's the wrong one for this 19 and will shut down + I am not even sure if there is one for the 19MK1. Remember these restore disks is not like most disk, these are a image of the harddrive when it left the factory.Banshee wrote:COA is for XP but I have some genuine codes from my MSDN accounttoughasnails wrote:Is this what you COA sticker is "Vista" ?? I think Rob only has XP for the MK1.Banshee wrote:
