Not able to find drivers for my paticular model number
oceanboy777
#1 Post by oceanboy777 »
Hi
So I went to several sites, including Panasonic, and tried to look up my model number. The way it was explained to me is the the letter after the model number (CF-19) is used to give me some information and lead me down the right path. Like MK1 or MK2. I cant find ANY CF-19 with a "P" after it
Here's my complete number CF-19PJRFXAM
I did find this but it still doesn't help me find the three missing driver for unknown devices.
Model Number:
CF-19PJRFXAM Status:
DISCONTINUED MSRP:
$4,579
Description: WinXP (Vista COA), Intel Core 2 Duo SU9300 1.20GHz, 10.4" XGA Touch, 160GB, 2GB, No WLAN, No Bluetooth, Dual Pass, TPM, GPS, Rubber Backlit Keyboard, Smartcard, No Absolute BIOS, No Drive, Toughbook Preferred
Thank you in advance for any suggestions!!!
safn1949
Re: Not able to find drivers for my paticular model number
#2 Post by safn1949 »
Mk3 is what you have,go to the panny site and download the drivers for that. Unknown will be misc driver and hotkey driver for 2 of them,I believe. Go and grab the Mk 3 folder with the download manager and then we can go thru it.
oceanboy777
#3 Post by oceanboy777 »
Thank you for letting me know its a MK3
However, when I go to panny site there are three different mk3's. Its confusing on which one to use. I installed win 7 pro 64 bit on this machine. Should I have used 32 instead?
#4 Post by toughasnails »
Well yes I would of . The question here is do you need 64? To get 64bit running you will need to do some looking for drivers.
oceanboy777
#5 Post by oceanboy777 »
Hi
I'm not going to keep this one so I don't mind that there's a 32 bit if it means finding drivers are easier. Is that what you're saying?
Thank you
#6 Post by toughasnails »
The 32bit will be a lot easier to find...all on Panasonic 's Web page
oceanboy777
#7 Post by oceanboy777 »
THANK YOU! I'll reinstall. Another Panasonic lesson learned. HA!
#8 Post by ADOR »
It can be done, but you have to look though and mis-match drivers from other models to make it work.
oceanboy777
#9 Post by oceanboy777 »
I want it to be simple because I'm selling it and don't care what bit OS it has. So thanks again for the lessons
oceanboy777
#10 Post by oceanboy777 »
OK...I now have Win 7 Pro 32bit installed with the same three unknowns devices showing up. Some said go to the panny site and get the drives for a MK3 but there are 3 MK3 driver sets.
Please help
thanks
