CF-29MK4 Mint 17 Firefox no run.(SOLVED)
I did a fresh install of Mint 17 XFCE on my CF-29MK4. After installing the updates available for the fresh install, Firefox will not run. I get a Profile Missing error. I have searched for a fix with no luck.
Uninstall and reinstall does not fix the problem.
Anyone know how to fix this?
And no, I don't want to run a different browser. Thanks.
Re: CF-29MK4 Mint 17 Firefox no run.
Try a portable version of Firefox?
J'd, you bet. Delete profile, create new profile, click the Firefox entry in the start menu and.....Profile Missing.
Shawn, no I have not, but I will. Thanks.
In terminal take a look at
I tried opening firefox using
Performed o.k. offered to rebuild since I use another browser and haven't used it in a long time.
I ignore the glib object warnings.
man firefox
firefox -browser
Nope, no change, J'd.
I started a thread on the Mint forum as well. I will report any findings.
Profiles are stored in .mozilla/firefox in the user's home directory. If you got nothing to lose, the easiest way is to delete it then restart Firefox. Otherwise check the contents of profile.ini to see if it makes sense, like this:
The Path should correspond to a directory of the same name inside ./mozilla/firefox . StartWithLastProfile and IsRelative should be set to 1.
[General]
StartWithLastProfile=1
[Profile0]
Name=default
IsRelative=1
Path=523i13xf.default
The profile.ini file looks identical to yours, except the entry after Path= is different, but corresponds to the correct profile.
Deleting the profile made no difference. Same profile missing error when I try and run FF.
Thanks.
Thanks.
Did you delete the firefox directory or just the profile? I'd even try to zap the .mozilla directory and see if it gets recreated, with or without error, when firefox runs. Also, I'd run firefox in a terminal to examine any other messages. The few times I've encountered profile errors, deleting the firefox directory seemed to be the easiest fix.
If it still turns to crap, try running firefox while specifying the full path to the profile directory like this example:
Obviously the above path should vary according to your situation.
firefox -profile "/home/username/.mozilla/firefox/523i13xf.default/"
I deleted the /.mozilla folder, no diff. It does get recreated when I try and run FF afterwards. FF still will not run, Profile Missing error.
Here is a link to the other thread, I have posted the output from terminal.
http://forums.linuxmint.com/viewtopic.php?f=47&t=181748
I can not direct it straight to the profile until FF runs. ATM inside the /.mozilla/firefox/ folder is a Crash Reports folder, inside that there is a file InstallTimexxxx... and an Events folder that is empty. I would have to run FF from terminal using sudo, in order to generate a default profile, no other way will run FF.
