inb4 someone saying "by NOT testing the IP65 rating of it! (aka sitting on the #8chan IRC channel while showering)"
Thanks to safn1949 I brought a CF-19 Mk2, serial number CF-19FHGAAAM, has no caddy and a cracked back half of screen (or whatever you explain it, the back panel of the screen case? idk), but that doesn't bother me, where should I buy a HD caddy? cheapest I seen on Ebay is 61 euros with shipping from Germany, and takes 3-4 days to come in the mail.. should I go for it or wait?
Brought a CF-19, what should I do first?
Re: Brought a CF-19, what should I do first?
Yes go with that one , it's going to be a lot faster. Cost a little more but you don't have to wait a month to get it
Blair
Just remove that cover and slap a piece of waterproof tape on the inside of the crack....done deal until you get the bucks for a used cover. I use eternabond because I have some for the rv roof.
Tape will work..but..do you have a source for JBWeld Epoxy? Tape the outside temporarily put JBWeld on the inside so the ugly doesn't show. Pull the tape just before the epoxy sets.
- Springfield
Good ideas to repair the lid. Just don't let Rob jump on it, especially after he's had a few beers . . . .
