OpenSuSe on the CF-18, can't get TS calibrated?!
My TS is apparently un-calibrateable, whenever I do calibrate it with Xinput-Calibrator and save the stuff in a .conf file+reboot, it still won't work properly? It's acting like a touchpad for some reason. (can only move left-right)
Last edited by WittgensteinSergeant on Tue Oct 07, 2014 12:28 pm, edited 1 time in total.
Re: OpenSuSe on the CF-18, can't get TS calibrated?!
What is your full CF-18 model number as stated in BIOS?
Calibration should be immediate, with the conf file for saving the settings permanently. Is it at least working right after calibration?
It acts like a touchpad?
CF-18DHB11GG
CF-18DHB11GG
Sorry, I thought I sent this......One more time.
What is output from:
Thank you.
| is shifted \
dmesg | grep PS/2
dmesg | grep input
| is shifted \
I'll do this later tomorrow, school is in the way for now ;cSadlmkr wrote:Sorry, I thought I sent this......One more time.
dmesg | grep PS/2
Thank you.Code: Select all
dmesg | grep input
| is shifted \
toughbook@linux-oy6o:~> dmesg | grep PS/2
[ 1.561080] i8042: PNP: PS/2 Controller [PNP0303:K101,FJC6000:MOU2] at 0x60,0x64 irq 1,12
[ 1.564512] mousedev: PS/2 mouse device common for all mice
[ 2.161186] input: LBPS/2 Fujitsu Lifebook TouchScreen as /devices/platform/i8042/serio3/input/input1
[ 3.339701] input: PS/2 Generic Mouse as /devices/platform/i8042/serio4/input/input2
toughbook@linux-oy6o:~> dmesg | grep input
[ 1.597115] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 3.477407] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/LNXVIDEO:00/input/input3
[ 3.484664] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input4
[ 3.488492] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input5
[ 3.497381] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[ 19.851142] input: Panasonic Laptop Support as /devices/virtual/input/input7
[ 20.230696] input: PC Speaker as /devices/platform/pcspkr/input/input8
I'm not exactly how you would equate a left-right only movement to a touchpad since that would also indicate something wrong with the touchpad itself.
Anyway, do you already have an /etc/X11/xorg.conf file on your system?
If you mean a folder like that, yiss I do.kode-niner wrote:I'm not exactly how you would equate a left-right only movement to a touchpad since that would also indicate something wrong with the touchpad itself.
Touchpad is working fine though?
I mean, quite precisely, the /etc/X11/xorg.conf file. Not /etc/X11/xorg.conf.d directory. If you have an xorg.conf file it may have conflicting sections with files you may have in the xorg.conf.d directory. If you do not have a xorg.conf file, this simplifies our troubleshooting.
If you followed the instructions in Jeff's really cool thread here:
viewtopic.php?f=39&t=1960
...then you have created a file called:
Jeff, feel free to chime in, here. I've never owned a CF-18.
cheers!
Can you please explain to me exactly how only moving left-right equates to acting like a touchpad? I fear there may be some sort of language barrier here.WittgensteinSergeant wrote:It's acting like a touchpad for some reason. (can only move left-right)
Can you show us the contents of this file? We'll do our best to help you./etc/X11/xorg.conf.d/99-calibration.conf
cheers!
It only moves side to side, not up or down. And when I calibrate the screen, it does the same.kode-niner wrote:I mean, quite precisely, the /etc/X11/xorg.conf file. Not /etc/X11/xorg.conf.d directory. If you have an xorg.conf file it may have conflicting sections with files you may have in the xorg.conf.d directory. If you do not have a xorg.conf file, this simplifies our troubleshooting.
...then you have created a file called:Can you show us the contents of this file? We'll do our best to help you./etc/X11/xorg.conf.d/99-calibration.conf
cheers!
Section "InputClass"
Identifier "calibration"
MatchProduct "LBPS/2 Fujitsu LifeBook TouchScreen"
Option "Calibration" "73 891 1041 1041"
Option "SwapAxes" "0"
EndSection
