MK-5 SD Card capacity Using Linux
plateaugame
#1 Post by plateaugame »
What's the maximum SD card capacity that will work with integrated SD Card reader on the MK-5 CF-18? (Using Linux.)
Two CF-18NJHZEBM, SSD, Navigatrix 0.5
One CF-18NDHZXVM, Navigatrix 0.5
Banshee
Re: MK-5 SD Card capacity
#2 Post by Banshee »
plateaugame wrote:What's the maximum SD card capacity that will work with integrated SD Card reader on the MK-5 CF-18? (Using Linux.)
What version of Linux?
plateaugame
#3 Post by plateaugame »
Banshee wrote:
plateaugame wrote:What's the maximum SD card capacity that will work with the integrated SD Card reader on the MK-5 CF-18? (Using Linux.)
Navigatrix 0.5 (August 2014)
Re: MK-5 SD Card capacity Using Linux
#4 Post by SHEEPMAN! »
PLEASE give the full model number from first page of bios.
What's the bios and ec from first bios page?
HEY all....does CF-18 MK5 have a bios upgrade? ...related to SD reader...
Azrial
#5 Post by Azrial »
Well it is not a limitation of the OS, I am running Ubuntu 14.04 x64 on a CF-30 Mk2 and I have a 64GB XCHD card in it. I am using FUSE/ ExFAT with it. See: https://code.google.com/p/exfat/
plateaugame
#6 Post by plateaugame »
Sadlmkr wrote:PLEASE give the full model number from first page of bios.
Model number: CF-18NJHZEBM
Bios: V5.00L10
Embedded Controller: V5.00L11
plateaugame
#7 Post by plateaugame »
Bios: V5.00L10
My hope is that I can load the ~50GB offline wikipedia on a 64GB SD card.
#8 Post by SHEEPMAN! »
I thought Shawn would know.
O.K....I researched quite a bit....and Azrial's answer is closest.
You need a friend..."Hey if I buy this and it doesn't work will you take it kind of friend"
plateaugame
#9 Post by plateaugame »
Azrial wrote:Well it is not a limitation of the OS, I am running Ubuntu 14.04 x64 on a CF-30 Mk2 and I have a 64GB XCHD card in it. I am using FUSE/ ExFAT with it. See: https://code.google.com/p/exfat/
Ok so to try this I'm going to need to follow a procedure like this:
http://www.namhuy.net/872/how-to-enable ... buntu.html
Is there a better one?
BTW, I saw some marketing literature that touts the Mark-5s as SDHC compliant. I think that means that device will not read SDXC cards (which all SDs above 32GB are, I believe). On a first pass of simply trying a 32GB SDHC in the in the slot worked, and a 64GB SDXC didn't, but that _could_ only mean that I've got to do the exFat stuff above.
plateaugame
#10 Post by plateaugame »
Got it working. All I needed to do is format the SDXC card as ext4 using the Navigatrix/linux GParted utility.
