ISO: CF-18 emmisive keyboard
crashomatic
#1 Post by crashomatic »
Just picked up a CF-18, looking for the emmisive backlit keyboard for it. Not looking for new, used is fine.
Re: ISO: CF-18 emmisive keyboard
Rubber or emissive? Emissives cost $272.00 new are are impossible to find used.
#3 Post by toughasnails »
crashomatic wrote: Not looking for new, used is fine.
As Shawn said $272.00 for new but if you are lucky to find used you still will be looking at $150.00 - $200.00 . Reason being is these things are hard to find.
crashomatic
#4 Post by crashomatic »
Figured they were hard to come by :/ How about a rubber?
#5 Post by toughasnails »
#6 Post by ADOR »
Just remember the rubber is a pain to type on but you can get use to it.
