Used Batteries
twillingham
Used Batteries
#1 Post by twillingham »
I have heard people on this forum indicating that they renew old batteries. I have two original panasonic batteries for a cf-28 and cf-29 that i have replaced. If anybody would like these batteries let me know THanks
Toughbook
Re: Used Batteries
#2 Post by Toughbook »
How did you reprogram the chip inside? That is what tells the batteries how old they are and how much charge to take. I have rebuilt several CF-28 batteries to no avail... You must be able to reprogram them or the new batteries are wasted. The only way that I know around this would be to replace the batteries when the battery pack is new and replace with a higher capacity battery.
twillingham
Re: Used Batteries
#3 Post by twillingham »
I am not saying that I did any work on the old batteries I am simply saying I replaced two batteries with new ones. I have two old batteries for anyone who wants to take a shot at getting back up to speed.
Azrial
Re: Used Batteries
#4 Post by Azrial »
Toughbook wrote:How did you reprogram the chip inside? That is what tells the batteries how old they are and how much charge to take. I have rebuilt several CF-28 batteries to no avail... You must be able to reprogram them or the new batteries are wasted. The only way that I know around this would be to replace the batteries when the battery pack is new and replace with a higher capacity battery.
I am not doubting you but that certainly is a novel thing for a battery to have. Why would they have to program obsolescence into the battery? I mean isn't this reduction the the ability to hold a charge is a natural byproduct of a battery aging?
I ask because I really want to know.
nine
Re: Used Batteries
#5 Post by nine »
I noticed an interesting thing earlier this week when I refreshed the battery in a CF-29 I got. It actually ended up reporting a HIGHER fully charged capacity after refresh. I know this is different behavior than the CF-28's, which would only lower the capacity. This got me wondering if the CF-29 batteries might be rebuildable?
anyone tried it? I don't have any 29 batteries that are dead enough for me to tear in to, or I'd consider doing it myself
nine
nine
Toughbooks, I have a few :)
twillingham
Re: Used Batteries
#6 Post by twillingham »
i have an old cf29 battery and 28
