hi i got a cf 19 core duo and started upgrading!
i have 4 gig ram installed and mostly available, 1tB hybrid drive and sierra mc8780 gps/3g card, and now trying to cram in a rtl/rt820 based dvb-t card that will give me a radio receiver covering 24mhz to 1800mhz for gnuradio utilities.
im triple booting a ubuntu 13 on its own partition and puppy co-existing with xp.
xp finally gets 3g on uk tmobile, but only an older version of ubuntu sees it. puppy doesnt.
same with the touchpad, although touchscreen works ok.
im hoping to be able to ditch xp as soon as ubuntu 13 or xubuntu sees all devices.
i wonder if anyone else has the sierra card installed correct?
i also wonder if anyone has tried to do a puppy remaster for toughbook.
the purpose is to use the cf19 as navigation, cis radar, vhf monitoring, and weather fax/sat fax on a boat. im routing the ext ant from the sierra card to an external sma connector for a gps antenna as there is no room for the ceramic patch i bought for it.
any ideas or suggestions? do you think i will need to recompile ubuntu to see the sierra card?
ubuntu 13 and cf19 and sierra mc8780 gps/3g card
Re: ubuntu 13 and cf19 and sierra mc8780 gps/3g card
What are the results of:
$dmesg | grep Sierra
$dmesg | grep Intel
($dmesg | grep input) # or( $lsinput) #two different lines. Dmesg quits reading at the #.
$lsusb
I saw one the other day for a Gobi install. IOW everything working.
Last night I used OpenCPN. Boat related and the author is bilingual. Linux and the other language.
More on the card later. If it's anything like Gobi you will have 5? entries.
ssd@ssd-CF-53JULA21M ~ $ dmesg | grep Sierra
[ 2.367166] usb 1-1.2: Manufacturer: Sierra Wireless, Incorporated
ssd@ssd-CF-53JULA21M ~ $ lsinput
The program 'lsinput' is currently not installed. You can install it by typing:
sudo apt-get install input-utils
ssd@ssd-CF-53JULA21M ~ $ sudo apt-get install input-utils
[sudo] password for ssd:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
input-utils
0 upgraded, 1 newly installed, 0 to remove and 15 not upgraded.
Need to get 19.9 kB of archives.
After this operation, 108 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu/ saucy/universe input-utils i386 1.0-1 [19.9 kB]
Fetched 19.9 kB in 0s (30.2 kB/s)
Selecting previously unselected package input-utils.
(Reading database ... 162788 files and directories currently installed.)
Unpacking input-utils (from .../input-utils_1.0-1_i386.deb) ...
Processing triggers for man-db ...
Setting up input-utils (1.0-1) ...
/dev/input/event0
bustype : BUS_HOST
vendor : 0x0
product : 0x5
version : 0
phys : "PNP0C0D/button/input0"
bits ev : EV_SYN EV_SW
/dev/input/event1
bustype : BUS_HOST
vendor : 0x0
product : 0x1
version : 0
phys : "PNP0C0C/button/input0"
bits ev : EV_SYN EV_KEY
/dev/input/event2
bustype : BUS_HOST
vendor : 0x0
product : 0x1
version : 0
phys : "LNXPWRBN/button/input0"
/dev/input/event3
bustype : BUS_I8042
vendor : 0x1
product : 0x1
version : 43841
name : "AT Translated Set 2 keyboard"
phys : "isa0060/serio0/input0"
bits ev : EV_SYN EV_KEY EV_MSC EV_LED EV_REP
/dev/input/event4
bustype : BUS_USB
vendor : 0x430
product : 0x532
version : 273
name : "Fujitsu Component USB Touch Pane"
phys : "usb-0000:00:1d.0-1.7/input0"
uniq : ""
bits ev : EV_SYN EV_KEY EV_ABS EV_MSC
/dev/input/event5
bustype : BUS_HOST
vendor : 0x0
product : 0x6
version : 0
phys : "LNXVIDEO/video/input0"
/dev/input/event6
bustype : BUS_HOST
vendor : 0x1
product : 0x1
version : 256
name : "Panasonic Laptop Support"
phys : "panasonic/hkey0"
/dev/input/event7
bustype : (null)
vendor : 0x0
product : 0x0
version : 0
name : "HDA Intel PCH HDMI/DP,pcm=7"
phys : "ALSA"
/dev/input/event8
bustype : (null)
vendor : 0x0
product : 0x0
version : 0
name : "HDA Intel PCH HDMI/DP,pcm=3"
phys : "ALSA"
/dev/input/event9
bustype : (null)
vendor : 0x0
product : 0x0
version : 0
name : "HDA Intel PCH Front Headphone"
phys : "ALSA"
/dev/input/event10
bustype : (null)
vendor : 0x0
product : 0x0
version : 0
name : "HDA Intel PCH Mic"
phys : "ALSA"
/dev/input/event11
bustype : BUS_I8042
vendor : 0x2
product : 0x7
version : 433
name : "SynPS/2 Synaptics TouchPad"
phys : "isa0060/serio2/input0"
ssd@ssd-CF-53JULA21M ~ $ lsusb
Bus 002 Device 003: ID 0430:0532 Sun Microsystems, Inc.
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 005: ID 147e:2016 Upek Biometric Touchchip/Touchstrip Fingerprint Sensor
Bus 001 Device 004: ID 1199:68a2 Sierra Wireless, Inc.
Bus 001 Device 003: ID 044e:301d Alps Electric Co., Ltd
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Here is mine with only Gobi GPS working.
What groups are you allowed.
$groups
$dmesg | grep Intel
$lsusb
input-utils
/dev/input/event0
bustype : BUS_HOST
vendor : 0x0
product : 0x5
version : 0
/dev/input/event1
bustype : BUS_HOST
vendor : 0x0
product : 0x1
version : 0
/dev/input/event2
bustype : BUS_HOST
vendor : 0x0
product : 0x1
version : 0
/dev/input/event3
bustype : BUS_I8042
vendor : 0x1
product : 0x1
version : 43841
/dev/input/event4
bustype : BUS_USB
vendor : 0x430
product : 0x532
version : 273
uniq : ""
/dev/input/event5
bustype : BUS_HOST
vendor : 0x0
product : 0x6
version : 0
/dev/input/event6
bustype : BUS_HOST
vendor : 0x1
product : 0x1
version : 256
/dev/input/event7
bustype : (null)
vendor : 0x0
product : 0x0
version : 0
phys : "ALSA"
/dev/input/event8
bustype : (null)
vendor : 0x0
product : 0x0
version : 0
phys : "ALSA"
/dev/input/event9
bustype : (null)
vendor : 0x0
product : 0x0
version : 0
phys : "ALSA"
/dev/input/event10
bustype : (null)
vendor : 0x0
product : 0x0
version : 0
phys : "ALSA"
/dev/input/event11
bustype : BUS_I8042
vendor : 0x2
product : 0x7
version : 433
$groups
Hope that didn't cause you to choke.
Full model# on your unit?
Dip switches? I'm running two up two down for UNDP.??? on a CF-19MK2.
Another client checked in and I need to get back to him.
Good luck.
Welcome to the L side of the nuthouse.
J'd (just once it's hyphenated for jayburd)
Good luck.
