Asus Gobi 2000 Card Drivers
Re: Asus Gobi 2000 Card Drivers
You sir are a gent!!!!!!
What part numbers am I looking for of a card that will work before I go pot lucking it again?
Is the one in the picture correct?
Failing that, do you by any chance know where I could buy one or anyone on here that I could purchase one from?
The card in the auction you linked to has the correct SKU - 1100984, so if it is a picture of the actual card you are buying, and not a stock picture, then it should work for you.
You can contact Rob to buy a Panasonic branded Gobi2000. Will not be as cheap as on the bay, but you know you have a factory unit.
The files have been uploaded, waiting on them being moved to the public downloads server so I can post the link for you.
Fantastic
Many thanks
Many thanks
Which one do I need mate the 47.8MB one or the 5.2MB one?
I would assume the bigger one.
Presumably the package is so big because it contains a connection manager as well?
Or would I be able to continue using Tough Connect? Are there any configurable settings for the GPS part of the module?
Sorry to bombard you with questions
I have no idea as I have never used, or even opened them. I grabbed the drivers when someone posted a link to the Panisonci UK site. If it is like the one for Canadian carriers, it will have the drivers and software in one package. The other file in the folder I uploaded is a wireless switch disable utility. It was with the connection software on the Panasonic site, so I left it in there. You should be able to setup the GPS through the connection software.
So I've bit the bullet and I've brought it
As soon as it arrives I'll keep you posted with my progress
I hope it works out for you.
