CF30 backlight problem
Svdharma
#1 Post by Svdharma »
Please forgive me if this has already been covered, I have been searching for a while now and I have not found what I was looking for. My CF30 has an issue with the backlight. It works, but it will only light up very dimly most of the time. Every once and I while I turn on the computer and it is super bright though. I have never seen it flicker or get darker, it only seems to change brightness when I turn off the computer or put it on standby, which leads me to think it is a software problem and not a short or a broken backlight. When the backlight seems to be working correctly, the brightness keys work, but when it is dim, they do nothing. Does anyone know how to go about fixing this?
-Svdharma
Re: CF30 backlight problem
#2 Post by toughasnails »
Welcome to Toughbook Talk
Your keyboard should have 4 settings, do all 4 work... press and hold Fn and press F12 for each setting. Let me know what happens
Svdharma
#3 Post by Svdharma »
You mean that "F1" or "F2" combined with "Fn", right? Right now I think the backlight is working normally. When I press "Fn" combined with "F1" the brightness goes down, combined with "F2" the brightness goes up. It goes through around 20 levels of brightness. "F12" combined with "Fn" does nothing.
When the back light stops working properly, it will be stuck at a level of brightness close to the lowest level available normally.
#4 Post by toughasnails »
Well do I feel stupid :doh: . Guess I read it wrong.
#5 Post by Shawn »
Here you go Blair..... :boing:
:lauging: :lauging: :lauging: :lauging: :lauging: :lauging: :lauging: :lauging: :lauging: :lauging: :lauging: :lauging:
#6 Post by toughasnails »
Thanks Shawn...after I made that last post I lost my internet until now. It's been one of them days
#7 Post by teo »
Blair has to many to think about. Take it easy, man!
Svdharma
#8 Post by Svdharma »
So my computer is too hot and that is why the screen will not brighten? That sounds like a much bigger problem than I anticipated.
Svdharma
#9 Post by Svdharma »
Well, I just stuck my computer in the freezer for five minutes, took it out, restarted it, and what do you know? Full brightness.
#10 Post by Shawn »
does it feel warm? lcd warm or base of laptop..if the base is warm, thermal pads need changed.
