BIOS Password
- twillingham
BIOS Password
Can anybody help with bios password and how to reset it. I recently got some information and how to do it. I took out the battery and unplugged the piece going into the motherboard that was under the memory cover. I left it undone all night and tried to enter the bios and still asking me for a password. Does anyone a different method
- Silver Trooper
Re: BIOS Password
This may sound like a stupid question, but you did pull the main battery?
- twillingham
Re: BIOS Password
No can you direct me on how to get to it.
- Silver Trooper
Re: BIOS Password
As you look down from the front, there will be two doors to the left, the one towards the front is the battery. Open the door and pull the tab to remove the battery. Pull both batteries (main and BIOS) and leave them out for at least an hour. That should do the trick.
- twillingham
Re: BIOS Password
i pulled the main battery and dont see the cmos battery is it in a different compartment
- twillingham
Re: BIOS Password
i have pulled the main battery out where is the cmos battery located
Re: BIOS Password
twillingham wrote:No can you direct me on how to get to it.
dam..it, I type to long and when I hit the submit button I need to login again and its all gone. Anyway, Sorry I need to erased my posted ans.
This discussion suppose to be on hidden area. "Rob" or "Alex" Can you move this to a hidden discussion.
- twillingham
Re: BIOS Password
this is the yellow round battery with black and red wire attached to it and runs to the mobo and the plug is connected to the mobo and you can access the plug under the memory cover i disconnected it last night all night and that didnt work
Re: BIOS Password
I'm not going to move this to the hidden area yet. Teo, just post whatever you were going to post.
- Silver Trooper
Re: BIOS Password
But did you have BOTH the backup (yellow) battery AND the main battery out at the same time? Pull both, wait an hour or so and then put them back in and try again. Oh, and not to forget, DO NOT have the unit on AC power. NO power, nothing, for at least an hour!twillingham wrote:this is the yellow round battery with black and red wire attached to it and runs to the mobo and the plug is connected to the mobo and you can access the plug under the memory cover i disconnected it last night all night and that didnt work
