BIOS Password
- twillingham
Re: BIOS Password
yes i had both pulled and left out all night got up this morning and still asking me for password
Re: BIOS Password
If you have the floppy drive . either the media bay unit or a usb unit
Boot into dos and run "KillCMOS"
http://majorgeeks.com/KillCMOS_d2969.html
It will wipe the bios clean
Alex
Alex
![Image](http://multiply.com/mu/afterinfo/image/3:multiplyclipart/photos/94/1200x120/7/cat-playi.gif?et=zg1SwFxNJSWtcPPK8vQAVw&nmid=110465854)
- Silver Trooper
Re: BIOS Password
There are programs that you can use off a floppy, but someone will have to chime in as I have never used one (never had to). I have always used the battery removal with success, but have never tried on a CF-29. I have heard rumors that the battery pull would not work on some of the newer models, but I cannot confirm that.
- twillingham
Re: BIOS Password
I cant believe it I ran KillCMOS program in DOS and still no luck
- twillingham
Re: BIOS Password
Killcomos didnt work, after I reboot from killcmos, it goes to a screen that says, Error, System CMOS checksum bad
Default configuration used
Press F2 to setup and when I hit f2 it goes right back to enter password
What do you think
What do you think
Re: BIOS Password
twillingham ....you have mail
Hiren's Boot CD
Blair ![:spinny: :spinny:](./images/smilies/happy3.gif)
![:) :)](./images/smilies/smile.gif)
Hiren's Boot CD
Re: BIOS Password
- twillingham
Re: BIOS Password
As tough as this laptop bios is to get into I am beginning to wonder what is the benefit to getting into the bios anyway ![:pat: :pat:](./images/smilies/pat.gif)
Re: BIOS Password
You do have a very good point.
I got my battery from the below seller.I get 4 hours from it,very high s/h charge but total I paid about $35.00 for it ,I was the only bidder
http://cgi.ebay.com/Panasonic-CF-VZSU29 ... tsupported
Re: BIOS Password
My way that hasn't failed yet:
1. Remove ALL power (batteries, MB Battery, AC Power, Solar Power, Wind Power, Hydro power, fart power, etc)
2. Remove Hard Drive/Caddy
3. Unplug CMOS battery
4. Cycle power switch 2-3 times for 1-2 seconds each (discharges board)
5. Plug in AC power
6. Boot up a few times to BIOS
7. Unplug AC
8. Cycle power switch 2-3 times for 1-2 seconds each
9. Reconnect CMOS and boot up
If for some reason that does not work, then repeat to step 8 and then leave off overnight. 9 out of 10 times though it works.
5. Plug in AC power
7. Unplug AC
~Paul ![;) ;)](./images/smilies/wink.gif)
Philippians 4:6-7"
Panasonic CF-29 Toughbook - 1.6Ghz - 100 GB 7200 RPM HD - 1.5GB of RAM - GPS - Internal WiFi - Sierra Wireless EVDO - 13" Touchscreen - DVD/CDRW Drive - Media battery - BT enabled with BT PCMIA mouse - backlit keyboard -
Anyone for a game? Look for Doobi!! :p
http://www.letsplaychess.com
Philippians 4:6-7"
![:D :D](./images/smilies/biggrin.gif)
