CF-30KQPRSPM
The Panasonic configurator returns 'no result'. The ToughWiki does not have all the info:
K-Mk3
Q-13.3" XGA, 1000nit, touchscreen, dual RF
P-160GB HDD, 2GB ram
R-GPS, BT
S-? (has a cell card and sim reader in sled)
P-? (has a factory Win7 Pro COA on bottom case)
M-North America
S- for the WWAN, would it be a Gobi2000? I don't have the unit here at work, but I believe it had an HSDPA IMEI sticker on the bottom case.
P- seems to be for Windows 7 Pro as the COA is a Panasonic one that looks original, as compared to put on the case after it left the factory.
Anyone have the same model or able to fill in the blanks for certain?
Also, this unit had not been touched when I got it, only a wipe of the hdd and Win7 install (no factory drivers/apps), and when I went to add memory, the unit is running one 2GB stick of PC-6400. ToughWiki shows the Mk3 as having PC-5300.
Thank you.
Morgan
CF-30 Mk3 model number questions
Re: CF-30 Mk3 model number questions
Yes both memory will work in the 30..PC-5300 or PC-6400 but will only run at the lower speed. You can find the 6400 most of the time cheaper on ebay...$10-$15 for 2GB .
Blair
