Hello everyone! just got a CF-30 mark 2 and it is impressive
ckrowi
#1 Post by ckrowi »
I have been wanting one of these for a long time but finally price to savings ratio was right :)
I am still learning all about these, I have to admit that I am very surprised by the lack of coherent support from Panasonic and a little, no a lot upset by their refusal to provide drivers for windows 8 on a machine that is definitely fast enough to take advantage of the latest OS.
CF-30 MK2 , 250GB HD, 2GB , Touchscreen, W8 Pro (sort of working) , Bluetooth, GPS, Emissive Keyboard
Re: Hello everyone! just got a CF-30 mark 2 and it is impres
#2 Post by SHEEPMAN! »
As you may have discovered the place for support is right here. :) Welcome to the madhouse.
Just phrase a question on a particular subject and folks from around the world will do their best to help.
We have some scary smart individuals checking in here.
Present party excluded of course.
Again, welcome.
#3 Post by ADOR »
The Mk2 works better on windows 7 than the Mk1 so you are ahead already. Personally I didn't like what time I have spent helping a friend set up his windows 8, but willing to help if I can.
ckrowi
#4 Post by ckrowi »
ADOR wrote:Personally I didn't like what time I have spent helping a friend set up his windows 8, but willing to help if I can.
Thanks ADOR.
I got 64bit win8 running. I did an upgrade from windows XP. then I tried a clean install of win8 but had trouble with the Intel Dynamic Power Performance Management driver. I am next going to do a 32bit install cause the cf-30 will never have more than 4GB RAM anyways. I am planning on starting with a Vista restore, then an upgrade to Windows 8.
I have only a quick question or two. I don't need details, but some general pointers from someone who has succeeded would save me a few days of fiddling with drivers :)
Did you end up going with a 64bit or 32bit Windows 8 install?
Did you install Vista, then upgrade to Windows 7 and then upgrade to Windows 8?
or did you successfully go straight from Vista to Windows 8 bypassing the windows 7 installation?
