OpenSuSe on the CF-18, can't get TS calibrated?!
Re: OpenSuSe on the CF-18, can't get TS calibrated?!
Are you saying that your touchPAD only has one axis and only moves side-to-side? And your touchSCREEN is doing the exact same thing? Your problem description is frustratingly imprecise.
I think we need to see the contents of /var/log/Xorg.0.log now. Do you mind posting it here so we can take a look at it? Thanks.
				WittgensteinSergeant
>tfw being Dutch has it's negatives :ckode-niner wrote:Are you saying that your touchPAD only has one axis and only moves side-to-side? And your touchSCREEN is doing the exact same thing? Your problem description is frustratingly imprecise.
OT: Only my TS is doing that, my touchpad works fine, will post the .log later, i'm on my GT780 atm.
These calibration numbers you posted here seem suspicious of a bad touchscreen:
[/quote]
I won't have access to Linux or Toughbook till Sunday morning but the above numbers are very suspicious.
Just my two cents from the left coast.
More to follow...
Section "InputClass"
Identifier "calibration"
MatchProduct "LBPS/2 Fujitsu LifeBook TouchScreen"
Option "Calibration" "73 891 1041 1041"
Option "SwapAxes" "0"
EndSectionI won't have access to Linux or Toughbook till Sunday morning but the above numbers are very suspicious.
 More to follow...
CF-53    MX-Linux 21 Wildflower
Here's the log:
[    44.682]
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
[    44.682]
X.Org X Server 1.14.3.901 (1.14.4 RC 1)
Release Date: 2013-10-26
[    44.683] X Protocol Version 11, Revision 0
[    44.683] Build Operating System: openSUSE SUSE LINUX
[    44.683] Current Operating System: Linux linux-oy6o 3.11.10-21-default #1 SMP Mon Jul 21 15:28:46 UTC 2014 (9a9565d) i686
[    44.683] Kernel command line: root=/dev/disk/by-id/usb-IC25N020_ATCS04-0_ST_Killer-0:0-part2 quiet quiet liveinstall resume=/dev/disk/by-id/usb-IC25N020_ATCS04-0_ST_Killer-0:0-part1 splash=silent quiet
[    44.683] Build Date: 17 April 2014  05:36:11AM
[    44.683]
[    44.683] Current version of pixman: 0.30.2
[    44.683] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    44.683] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    44.683] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Oct 10 18:02:02 2014
[    44.686] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    44.686] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    44.688] (==) No Layout section.  Using the first Screen section.
[    44.688] (==) No screen section available. Using defaults.
[    44.688] (**) |-->Screen "Default Screen Section" (0)
[    44.688] (**) |   |-->Monitor "<default monitor>"
[    44.688] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[    44.689] (==) Automatically adding devices
[    44.689] (==) Automatically enabling devices
[    44.689] (==) Automatically adding GPU devices
[    45.085] (WW) The directory "/usr/share/fonts/misc/sgi" does not exist.
[    45.085] 	Entry deleted from font path.
[    45.085] (==) FontPath set to:
	/usr/share/fonts/misc:unscaled,
	/usr/share/fonts/Type1/,
	/usr/share/fonts/100dpi:unscaled,
	/usr/share/fonts/75dpi:unscaled,
	/usr/share/fonts/ghostscript/,
	/usr/share/fonts/cyrillic:unscaled,
	/usr/share/fonts/truetype/,
	built-ins
[    45.086] (==) ModulePath set to "/usr/lib/xorg/modules/updates,/usr/lib/xorg/modules"
[    45.086] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    45.086] (II) Loader magic: 0x8260620
[    45.086] (II) Module ABI versions:
[    45.086] 	X.Org ANSI C Emulation: 0.4
[    45.086] 	X.Org Video Driver: 14.1
[    45.086] 	X.Org XInput driver : 19.1
[    45.086] 	X.Org Server Extension : 7.0
[    45.087] (II) xfree86: Adding drm device (/dev/dri/card0)
[    45.090] (--) PCI:*(0:0:2:0) 8086:3582:10f7:8338 rev 2, Mem @ 0xe8000000/134217728, 0xe0000000/524288, I/O @ 0x00001800/8
[    45.090] (--) PCI: (0:0:2:1) 8086:3582:10f7:8338 rev 2, Mem @ 0xf0000000/134217728, 0xe0080000/524288
[    45.090] Initializing built-in extension Generic Event Extension
[    45.090] Initializing built-in extension SHAPE
[    45.090] Initializing built-in extension MIT-SHM
[    45.090] Initializing built-in extension XInputExtension
[    45.090] Initializing built-in extension XTEST
[    45.090] Initializing built-in extension BIG-REQUESTS
[    45.090] Initializing built-in extension SYNC
[    45.090] Initializing built-in extension XKEYBOARD
[    45.090] Initializing built-in extension XC-MISC
[    45.090] Initializing built-in extension SECURITY
[    45.090] Initializing built-in extension XINERAMA
[    45.090] Initializing built-in extension XFIXES
[    45.091] Initializing built-in extension RENDER
[    45.091] Initializing built-in extension RANDR
[    45.091] Initializing built-in extension COMPOSITE
[    45.091] Initializing built-in extension DAMAGE
[    45.091] Initializing built-in extension MIT-SCREEN-SAVER
[    45.091] Initializing built-in extension DOUBLE-BUFFER
[    45.091] Initializing built-in extension RECORD
[    45.091] Initializing built-in extension DPMS
[    45.091] Initializing built-in extension X-Resource
[    45.091] Initializing built-in extension XVideo
[    45.091] Initializing built-in extension XVideo-MotionCompensation
[    45.091] Initializing built-in extension XFree86-VidModeExtension
[    45.091] Initializing built-in extension XFree86-DGA
[    45.091] Initializing built-in extension XFree86-DRI
[    45.091] Initializing built-in extension DRI2
[    45.091] (II) "glx" will be loaded by default.
[    45.091] (II) LoadModule: "dri2"
[    45.091] (II) Module "dri2" already built-in
[    45.091] (II) LoadModule: "glamoregl"
[    45.152] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    45.159] (II) Module glamoregl: vendor="X.Org Foundation"
[    45.159] 	compiled for 1.14.3.901, module version = 0.5.1
[    45.159] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    45.159] (II) LoadModule: "glx"
[    45.190] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    45.190] (II) Module glx: vendor="X.Org Foundation"
[    45.190] 	compiled for 1.14.3.901, module version = 1.0.0
[    45.190] 	ABI class: X.Org Server Extension, version 7.0
[    45.190] (==) AIGLX enabled
[    45.190] Loading extension GLX
[    45.191] (==) Matched intel as autoconfigured driver 0
[    45.191] (==) Matched intel as autoconfigured driver 1
[    45.191] (==) Matched modesetting as autoconfigured driver 2
[    45.191] (==) Matched fbdev as autoconfigured driver 3
[    45.191] (==) Matched vesa as autoconfigured driver 4
[    45.191] (==) Assigned the driver to the xf86ConfigLayout
[    45.191] (II) LoadModule: "intel"
[    45.194] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[    45.195] (II) Module intel: vendor="X.Org Foundation"
[    45.195] 	compiled for 1.14.3.901, module version = 2.99.906
[    45.195] 	Module class: X.Org Video Driver
[    45.195] 	ABI class: X.Org Video Driver, version 14.1
[    45.195] (II) LoadModule: "modesetting"
[    45.198] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    45.198] (II) Module modesetting: vendor="X.Org Foundation"
[    45.199] 	compiled for 1.14.3.901, module version = 0.8.0
[    45.199] 	Module class: X.Org Video Driver
[    45.199] 	ABI class: X.Org Video Driver, version 14.1
[    45.199] (II) LoadModule: "fbdev"
[    45.202] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    45.203] (II) Module fbdev: vendor="X.Org Foundation"
[    45.203] 	compiled for 1.14.3, module version = 0.4.3
[    45.203] 	Module class: X.Org Video Driver
[    45.203] 	ABI class: X.Org Video Driver, version 14.1
[    45.203] (II) LoadModule: "vesa"
[    45.205] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    45.205] (II) Module vesa: vendor="X.Org Foundation"
[    45.205] 	compiled for 1.14.3, module version = 2.3.3
[    45.205] 	Module class: X.Org Video Driver
[    45.205] 	ABI class: X.Org Video Driver, version 14.1
[    45.205] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43, HD Graphics,
	HD Graphics 2000, HD Graphics 3000, HD Graphics 2500,
	HD Graphics 4000, HD Graphics P4000, HD Graphics 4600,
	HD Graphics 5000, HD Graphics P4600/P4700, Iris(TM) Graphics 5100,
	HD Graphics 4400, HD Graphics 4200, Iris(TM) Pro Graphics 5200
[    45.206] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    45.206] (II) FBDEV: driver for framebuffer: fbdev
[    45.206] (II) VESA: driver for VESA chipsets: vesa
[    45.206] (++) using VT number 7
[    45.207] (WW) Falling back to old probe method for modesetting
[    45.207] (WW) Falling back to old probe method for fbdev
[    45.207] (II) Loading sub module "fbdevhw"
[    45.207] (II) LoadModule: "fbdevhw"
[    45.208] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    45.208] (II) Module fbdevhw: vendor="X.Org Foundation"
[    45.208] 	compiled for 1.14.3.901, module version = 0.0.2
[    45.208] 	ABI class: X.Org Video Driver, version 14.1
[    45.208] (WW) Falling back to old probe method for vesa
[    45.209] (II) intel(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 15/16
[    45.209] (==) intel(0): Depth 15, (--) framebuffer bpp 16
[    45.209] (==) intel(0): RGB weight 555
[    45.209] (==) intel(0): Default visual is TrueColor
[    45.209] (--) intel(0): Integrated Graphics Chipset: Intel(R) 852GM/855GM
[    45.214] (--) intel(0): CPU: x86, sse2
[    45.214] (**) intel(0): Framebuffer tiled
[    45.214] (**) intel(0): Pixmaps tiled
[    45.214] (**) intel(0): "Tear free" disabled
[    45.214] (**) intel(0): Forcing per-crtc-pixmaps? no
[    45.214] (II) intel(0): Output LVDS1 has no monitor section
[    45.215] (--) intel(0): found backlight control interface panasonic (type 'platform')
[    45.215] (II) intel(0): Output VGA1 has no monitor section
[    45.215] (II) intel(0): Output VIRTUAL1 has no monitor section
[    45.215] (--) intel(0): Output LVDS1 using initial mode 1024x768 on pipe 1
[    45.215] (==) intel(0): DPI set to (96, 96)
[    45.215] (II) Loading sub module "dri2"
[    45.215] (II) LoadModule: "dri2"
[    45.215] (II) Module "dri2" already built-in
[    45.215] (II) UnloadModule: "modesetting"
[    45.215] (II) Unloading modesetting
[    45.215] (II) UnloadModule: "fbdev"
[    45.215] (II) Unloading fbdev
[    45.215] (II) UnloadSubModule: "fbdevhw"
[    45.215] (II) Unloading fbdevhw
[    45.215] (II) UnloadModule: "vesa"
[    45.215] (II) Unloading vesa
[    45.215] (II) intel(0): SNA initialized with Almador (gen2) backend
[    45.215] (==) intel(0): Backing store disabled
[    45.215] (==) intel(0): Silken mouse enabled
[    45.216] (II) intel(0): HW Cursor enabled
[    45.216] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    45.216] (==) intel(0): DPMS enabled
[    45.216] (II) intel(0): Textured video not supported on this hardware
[    45.216] (II) intel(0): [DRI2] Setup complete
[    45.216] (II) intel(0): [DRI2]   DRI driver: i915
[    45.216] (II) intel(0): direct rendering: DRI2 Enabled
[    45.216] (==) intel(0): hotplug detection: "enabled"
[    45.216] (--) RandR disabled
[    45.253] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[    45.253] (II) AIGLX: enabled GLX_INTEL_swap_event
[    45.253] (II) AIGLX: enabled GLX_ARB_create_context
[    45.253] (II) AIGLX: enabled GLX_ARB_create_context_profile
[    45.253] (II) AIGLX: enabled GLX_EXT_create_context_es2_profile
[    45.253] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[    45.253] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[    45.253] (II) AIGLX: Loaded and initialized i915
[    45.253] (II) GLX: Initialized DRI2 GL provider for screen 0
[    45.254] (II) intel(0): switch to mode 1024x768@60.0 on pipe 1 using LVDS1, position (0, 0), rotation normal
[    46.073] (II) intel(0): Setting screen physical size to 270 x 203
[    46.347] (II) config/udev: Adding input device Power Button (/dev/input/event6)
[    46.347] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    46.347] (**) Power Button: Applying InputClass "LocalKeyboard"
[    46.347] (II) LoadModule: "evdev"
[    46.350] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    46.421] (II) Module evdev: vendor="X.Org Foundation"
[    46.421] 	compiled for 1.14.3, module version = 2.8.2
[    46.421] 	Module class: X.Org XInput Driver
[    46.421] 	ABI class: X.Org XInput driver, version 19.1
[    46.421] (II) Using input driver 'evdev' for 'Power Button'
[    46.421] (**) Power Button: always reports core events
[    46.421] (**) evdev: Power Button: Device: "/dev/input/event6"
[    46.422] (--) evdev: Power Button: Vendor 0 Product 0x1
[    46.422] (--) evdev: Power Button: Found keys
[    46.422] (II) evdev: Power Button: Configuring as keyboard
[    46.422] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input6/event6"
[    46.422] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    46.422] (**) Option "xkb_rules" "evdev"
[    46.422] (**) Option "xkb_model" "pc104"
[    46.422] (**) Option "xkb_layout" "us_intl"
[    46.569] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[    46.569] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    46.569] (**) Video Bus: Applying InputClass "LocalKeyboard"
[    46.569] (II) Using input driver 'evdev' for 'Video Bus'
[    46.569] (**) Video Bus: always reports core events
[    46.569] (**) evdev: Video Bus: Device: "/dev/input/event3"
[    46.569] (--) evdev: Video Bus: Vendor 0 Product 0x6
[    46.569] (--) evdev: Video Bus: Found keys
[    46.569] (II) evdev: Video Bus: Configuring as keyboard
[    46.569] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A03:00/LNXVIDEO:00/input/input3/event3"
[    46.569] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    46.569] (**) Option "xkb_rules" "evdev"
[    46.569] (**) Option "xkb_model" "pc104"
[    46.569] (**) Option "xkb_layout" "us_intl"
[    46.570] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[    46.570] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    46.570] (**) Power Button: Applying InputClass "LocalKeyboard"
[    46.570] (II) Using input driver 'evdev' for 'Power Button'
[    46.570] (**) Power Button: always reports core events
[    46.570] (**) evdev: Power Button: Device: "/dev/input/event4"
[    46.570] (--) evdev: Power Button: Vendor 0 Product 0x1
[    46.570] (--) evdev: Power Button: Found keys
[    46.570] (II) evdev: Power Button: Configuring as keyboard
[    46.570] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input4/event4"
[    46.570] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[    46.570] (**) Option "xkb_rules" "evdev"
[    46.570] (**) Option "xkb_model" "pc104"
[    46.570] (**) Option "xkb_layout" "us_intl"
[    46.576] (II) config/udev: Adding input device Lid Switch (/dev/input/event5)
[    46.576] (II) No input driver specified, ignoring this device.
[    46.576] (II) This device may have been added with another device file.
[    46.576] (II) config/udev: Adding drm device (/dev/dri/card0)
[    46.578] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[    46.578] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    46.578] (**) AT Translated Set 2 keyboard: Applying InputClass "LocalKeyboard"
[    46.578] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[    46.578] (**) AT Translated Set 2 keyboard: always reports core events
[    46.578] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[    46.578] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[    46.578] (--) evdev: AT Translated Set 2 keyboard: Found keys
[    46.578] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[    46.578] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[    46.578] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 9)
[    46.578] (**) Option "xkb_rules" "evdev"
[    46.578] (**) Option "xkb_model" "pc104"
[    46.578] (**) Option "xkb_layout" "us_intl"
[    46.584] (II) config/udev: Adding input device LBPS/2 Fujitsu Lifebook TouchScreen (/dev/input/event1)
[    46.584] (**) LBPS/2 Fujitsu Lifebook TouchScreen: Applying InputClass "evdev touchscreen catchall"
[    46.584] (**) LBPS/2 Fujitsu Lifebook TouchScreen: Applying InputClass "calibration"
[    46.584] (II) Using input driver 'evdev' for 'LBPS/2 Fujitsu Lifebook TouchScreen'
[    46.584] (**) LBPS/2 Fujitsu Lifebook TouchScreen: always reports core events
[    46.584] (**) evdev: LBPS/2 Fujitsu Lifebook TouchScreen: Device: "/dev/input/event1"
[    46.584] (--) evdev: LBPS/2 Fujitsu Lifebook TouchScreen: Vendor 0x2 Product 0x9
[    46.584] (--) evdev: LBPS/2 Fujitsu Lifebook TouchScreen: Found absolute axes
[    46.584] (--) evdev: LBPS/2 Fujitsu Lifebook TouchScreen: Found x and y absolute axes
[    46.584] (--) evdev: LBPS/2 Fujitsu Lifebook TouchScreen: Found absolute touchscreen
[    46.585] (II) evdev: LBPS/2 Fujitsu Lifebook TouchScreen: Configuring as touchscreen
[    46.585] (**) evdev: LBPS/2 Fujitsu Lifebook TouchScreen: YAxisMapping: buttons 4 and 5
[    46.585] (**) evdev: LBPS/2 Fujitsu Lifebook TouchScreen: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    46.585] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio3/input/input1/event1"
[    46.585] (II) XINPUT: Adding extended input device "LBPS/2 Fujitsu Lifebook TouchScreen" (type: TOUCHSCREEN, id 10)
[    46.585] (II) evdev: LBPS/2 Fujitsu Lifebook TouchScreen: initialized for absolute axes.
[    46.585] (**) LBPS/2 Fujitsu Lifebook TouchScreen: (accel) keeping acceleration scheme 1
[    46.585] (**) LBPS/2 Fujitsu Lifebook TouchScreen: (accel) acceleration profile 0
[    46.585] (**) LBPS/2 Fujitsu Lifebook TouchScreen: (accel) acceleration factor: 2.000
[    46.585] (**) LBPS/2 Fujitsu Lifebook TouchScreen: (accel) acceleration threshold: 4
[    46.586] (II) config/udev: Adding input device LBPS/2 Fujitsu Lifebook TouchScreen (/dev/input/mouse0)
[    46.586] (**) LBPS/2 Fujitsu Lifebook TouchScreen: Applying InputClass "calibration"
[    46.586] (II) No input driver specified, ignoring this device.
[    46.586] (II) This device may have been added with another device file.
[    46.586] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/event2)
[    46.586] (**) PS/2 Generic Mouse: Applying InputClass "evdev pointer catchall"
[    46.586] (II) Using input driver 'evdev' for 'PS/2 Generic Mouse'
[    46.586] (**) PS/2 Generic Mouse: always reports core events
[    46.586] (**) evdev: PS/2 Generic Mouse: Device: "/dev/input/event2"
[    46.586] (--) evdev: PS/2 Generic Mouse: Vendor 0x2 Product 0x1
[    46.586] (--) evdev: PS/2 Generic Mouse: Found 3 mouse buttons
[    46.586] (--) evdev: PS/2 Generic Mouse: Found relative axes
[    46.586] (--) evdev: PS/2 Generic Mouse: Found x and y relative axes
[    46.586] (II) evdev: PS/2 Generic Mouse: Configuring as mouse
[    46.586] (**) evdev: PS/2 Generic Mouse: YAxisMapping: buttons 4 and 5
[    46.586] (**) evdev: PS/2 Generic Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    46.587] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio4/input/input2/event2"
[    46.587] (II) XINPUT: Adding extended input device "PS/2 Generic Mouse" (type: MOUSE, id 11)
[    46.587] (II) evdev: PS/2 Generic Mouse: initialized for relative axes.
[    46.587] (**) PS/2 Generic Mouse: (accel) keeping acceleration scheme 1
[    46.587] (**) PS/2 Generic Mouse: (accel) acceleration profile 0
[    46.587] (**) PS/2 Generic Mouse: (accel) acceleration factor: 2.000
[    46.587] (**) PS/2 Generic Mouse: (accel) acceleration threshold: 4
[    46.587] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/mouse1)
[    46.587] (II) No input driver specified, ignoring this device.
[    46.587] (II) This device may have been added with another device file.
[    46.588] (II) config/udev: Adding input device PC Speaker (/dev/input/event8)
[    46.588] (II) No input driver specified, ignoring this device.
[    46.588] (II) This device may have been added with another device file.
[    46.598] (II) config/udev: Adding input device Panasonic Laptop Support (/dev/input/event7)
[    46.598] (**) Panasonic Laptop Support: Applying InputClass "evdev keyboard catchall"
[    46.598] (**) Panasonic Laptop Support: Applying InputClass "LocalKeyboard"
[    46.598] (II) Using input driver 'evdev' for 'Panasonic Laptop Support'
[    46.598] (**) Panasonic Laptop Support: always reports core events
[    46.598] (**) evdev: Panasonic Laptop Support: Device: "/dev/input/event7"
[    46.598] (--) evdev: Panasonic Laptop Support: Vendor 0x1 Product 0x1
[    46.598] (--) evdev: Panasonic Laptop Support: Found keys
[    46.598] (II) evdev: Panasonic Laptop Support: Configuring as keyboard
[    46.599] (**) Option "config_info" "udev:/sys/devices/virtual/input/input7/event7"
[    46.599] (II) XINPUT: Adding extended input device "Panasonic Laptop Support" (type: KEYBOARD, id 12)
[    46.599] (**) Option "xkb_rules" "evdev"
[    46.599] (**) Option "xkb_model" "pc104"
[    46.599] (**) Option "xkb_layout" "us_intl"
At a minimum you have a bad element in the touchpanel or a bad cut and paste. Cleve is correct.
1046 in two places means no movement on that axis.
God damn it.. Oh well, gunna sell it in parts it is then.Sadlmkr wrote:At a minimum you have a bad element in the touchpanel or a bad cut and paste. Cleve is correct.
Yeah those last two values are min-Y and max-Y, vertical axis. One last thing I would try though is to re-run calibration but click the cross-hairs with the touchpad instead of the screen and force the dynamic calibration. But it does sound like that unit's going to the parts bin, sadly.
Done that, no bueno..kode-niner wrote:Yeah those last two values are min-Y and max-Y, vertical axis. One last thing I would try though is to re-run calibration but click the cross-hairs with the touchpad instead of the screen and force the dynamic calibration. But it does sound like that unit's going to the parts bin, sadly.
That's too bad. If you're handy with tools, it wouldn't hurt to crack it open and make sure the flex cable on the touch panel and the wires on the inverter and touchscreen boards are seated properly.
Also done that, no bueno..kode-niner wrote:That's too bad. If you're handy with tools, it wouldn't hurt to crack it open and make sure the flex cable on the touch panel and the wires on the inverter and touchscreen boards are seated properly.
