Mint 15 XFCE CF-29 any mark (1 to 5)
#1 Post by SHEEPMAN! »
UNCNDL1
Re: Mint 15 XFCE CF-29 any mark (1 to 5)
#2 Post by UNCNDL1 »
Jeff, I'm on a CF-29EWKGZKM with 13XFCE and yes, the mouse is driving me nuts. Followed your mouse tweak and when I pasted the command into editor, I get this message in Terminal:
"toughbook@toughbook-CF-29EWKGZKM ~/Desktop $ sudo gedit /etc/modprobe.d/psmouse.conf
[sudo] password for toughbook:
(gedit:2104): Gtk-WARNING **: Attempting to store changes into `/root/.local/share/recently-used.xbel', but failed: Failed to create file '/root/.local/share/recently-used.xbel.D7WP9W': No such file or directory"
Wondering if I copyied / pasted wrong or do I need to add/change directory first?
Best regards, Cleve
#3 Post by SHEEPMAN! »
I see that once in a while or similar. Don't know what it means but I have fixed it a couple times.
Or just ignored it. Permission setting may be an issue.
https://sites.google.com/site/tipsandtr ... tk-warning
I'll pay more attention.
UNCNDL1
#4 Post by UNCNDL1 »
Thanks Lefty,
tried your suggestion/link and now it is a-okay... :clapping:
#5 Post by SHEEPMAN! »
Hey Righty,
An explanation..in detail would be good.
1. Read my Post.
2. Ignored it.
3. Used info from the link.
Lefty
UNCNDL1
#6 Post by UNCNDL1 »
Lefty...followed the link below you provided:
Went into Terminal (not so scary now that I've calibrated the touchscreen)
ran the script and then re-booted....problem solved, I think....
I'm on a MK5 CF-29 with working touch using Mint13 LTS XFCE, and while typing this I have a movie running "Generation Kill", it's in the top half of the screen and TBT is in the bottom...The guy from Craigslist did not show for the showing/selling so going to put this up for sale on the site...Thanks Jeff :headbang:
UNCNDL1
#7 Post by UNCNDL1 »
I use these directions from time to time. Am on a MK3 CF-28 with older version of Navigatrix 0.4
(Ubuntu 12-13ish) and would sure like to speed up the mouse. Any thoughts or CF-28'ers using Linux?
UNCNDL1
#8 Post by UNCNDL1 »
bump in the road, watch out for potholes
UNCNDL1
#9 Post by UNCNDL1 »
I'm on a CF-29LTQGZBM-B (THANK YOU MORGAN)
Going to follow the linkage, and then install LMDE2Betsy (Debian Stable), reports to follow.
I know everyone else has a 30 and or a 31 with a SSD SATA drive, but there are plenty of these babies out there...
Thanks to Lefty for keeping on keeping on....
Bill_TN
#10 Post by Bill_TN »
Trying mint 17.3 in forced pae on a cf-29ETPGZKM. This is supposed to have touch screen. Will see.
